Siebel Enterprise Integration Manager Administration Guide > Siebel EIM Tables > EIM Table and Column Mappings >
Viewing Interface Column Mappings to Base Tables
Use Siebel Tools to view interface column mappings to base table columns.
To view interface column mappings to base tables
  1. Complete To view EIM table mappings to base tables.
  2. In the EIM Table Mappings window, select a base table.
  3. In the Object Explorer, expand EIM Table Mapping.
  4. Click Attribute Mapping.
    The Attribute Mappings window displays column mappings for the selected base table.
Figure 3 shows an example of viewing column mappings for the S_ADDR_ORG base table. (This example is specific to Siebel eBusiness Applications rather than Siebel Industry Applications.) In the Attribute Mappings list applet, for a selected base table mapping, you can find information about the mapping that has been defined between the EIM table column and the base table column. For example, Figure 3 shows that the S_ADDR_ORG.ADDR_NAME column has been mapped to the ADDR_ADDR_NAME (EIM_ACCOUNT) interface column.
Figure 3.  Viewing Interface Column Mappings to Base Tables
Click for full size image
