Siebel Forecasting Guide >
Forecasting User Properties
This section describes the user properties associated with a number of Forecasting business components. Forecasting user properties are found in Siebel Tools.
CAUTION:  Some Siebel Forecasting user properties are for internal use only. Adjusting user properties marked for internal use can affect the behavior of adjustments. Internal use only user properties should not be modified. They are included in this appendix for informational purposes only.
