Siebel Forecasting Guide > Forecasting User Properties >
Forecast 2000 - Forecast Item User Properties
Table 10 describes the user properties associated with the business component: Forecast 2000 - Forecast Item.
Table 10.  Forecast 2000 - Forecast Item
User Property
Adjustment: Adjustable
Indicates that adjustments are enabled on Forecast Item business component.
An adjustable business component supports the concept of hierarchical information sharing. When a manager modifies a subordinate's record, the changes are made to a copy of the record, not the actual subordinate record. Therefore, changes are not visible to the subordinate.
Also, the manager's record is visible to the positions above him, for example his change shadows the original record. The record created by the manager is called an adjustment of the original.
If adjustments are disabled, changes are made on the same record and are visible throughout the hierarchy.
Adjustment: Adjustable Field (N)
Field names on the Forecast 2000 - Forecast Item business component
Fields which managers can adjust.
If a field is not configured here, it appears to be uneditable to managers when they view forecast details included from subordinate forecasts.
Adjustment: Adjustment Allowed Field Name
Adjustment Allowed
Used internally.
Should not be disabled.
Adjustment: Adjustment Context BC Name
Used internally.
Value is the business component which includes information indicating the ownership or level of an adjustment record.
This is used to support copy-on-write implementation of adjustments. In Forecasting, the same record is visible in both manager and subordinate forecasts before adjustments and its context is the forecast it is being viewed under. When an adjustment is made, the adjusted record then takes its ownership from its context (the manager's forecast).
Adjustment: Adjustment Context Id Field Name
Owner Forecast Id
Used internally.
Field on Context business component which indicates position of owner.
Adjustment: Adjustment Flag Field Name
Adjusted Flag
Used internally.
Indicates if a record has been adjusted and is used in other methods. For example, it is used for determining if the user can invoke the Unadjust Record method.
NOTE:  The Adjusted Flag only gets set when the adjustment is made by a manager. It does not get set when the adjustment is made by the primary sales team member.
Adjustment: Adjustment For Id Field Name
Adjustment For Id
Used internally.
Field which stores base record identifier (usually, but not necessarily the value of row_id) that this record is an adjustment for.
Adjustment: Adjustment for Id Matching Field Name
Forecast Item Number
Used internally.
Field which, when matched against [Adjustment For Id], determines if a record has been adjusted. This is part of the criteria used in calculating the value of the Adjustment Flag.
Adjustment: Context BC Position Id Field Name
Owner Position Id
Used internally.
Field on the Context business component which stores the position of the owner. Because Siebel Forecasting is position-based, this links the user to the forecast record created. The position is used when calculating whether a record is visible.
Adjustment: InterTable
Used internally (default N).
Indicates whether this adjustable business component's visibility is determined by an intertable. The code would potentially need to modify the intertable when creating adjustments.
Adjustment: InterTable BC
Forecast 2000 - Forecast/Forecast Item
Used internally.
Indicates the business component that sits on the intertable.
Adjustment: InterTable Child Field Name
Forecast Item Id
Used internally.
Indicates the field on the intertable that stores the pointer id to this business component.
Adjustment: InterTable Parent Field Name
Forecast Id
Used internally.
Indicates the field on the intertable that stores the pointer to the parent (context) business component.
Adjustment: InterTable Update
Used internally.
Indicates whether or not the intertable should be updated during adjustments.
Adjustment: Owner Position Id Field Name
Owner Position Id.
Used internally.
Field on this business component which stores the owner's Position Id.
Revenue Associate List
When active, the associate applet shows the revenue, and not a standard child business component. It also applies the Associate Search Spec and the Forecast Date Range search when querying the Revenue business component.
When inactive, the behavior defaults to standard association and the business component is defined in the associate applet.
Revenue Field Map: <Forecast Item Field>
<Revenue Field>
Maps fields from the Revenue business component to the Forecast Item business component, which are copied when creating the forecast.
This is most commonly configured by administrators who have added fields to the Revenue business component and want the fields to be carried over in the forecast.
