Table 9. Forecast 2000 - Forecast
Associate: Completion Timeout (Client) |
120 (default) |
Maximum amount of time (in seconds) to wait on the client for a subordinate's forecast to finish before skipping the association and returning an error. |
Associate: Completion Timeout (Server) |
1200 (default) |
Maximum amount of time to wait (in seconds) on the server for a subordinate's forecast to finish before skipping the association and returning an error. |
Associate: Sleep Time Between Attempts |
5 (default) |
Amount of time to wait (in seconds) between checks for completion of subordinate's forecast. |
Forecast Analysis BC |
Forecast 2000 - Forecast Item Detail Flat |
The business component whose records are displayed in the child applet in the Analysis view, when parent records are selected for comparison. |
Forecast Rollup |
[Link Type] = LookupValue ('FCST_FCSTITEM_LINK_TYPE', 'Own Item') or [Link Type] = LookupValue ('FCST_FCSTITEM_LINK_TYPE', 'Item') |
If active, this search spec is applied on the Forecast Detail business component during rollup. |
Named Search: Forecast Series Date Range |
[Date] >= '&FCST_DATE_LOWER_BOUND' and [Date] <= '&FCST_END_DATE' |
If active, this search spec is applied to the Revenue business component during forecast creation. This is usually active to make sure that the revenues are within the Forecast Date range. If not active, administrators need to modify the Auto and Assoc search specs of the Forecast Series to include similar criteria if they want the revenues that enter the forecast to be limited by date. This search spec (as well as the Auto and Assoc search specs) can use special variables as defined in the Forecast Series and Forecast Series Date business components. |
Revenue Aggregation Field (N) |
Field names on the Forecast 2000 - Forecast Item Detail Flat business component |
The fields which are aggregated during forecast rollup. Rollup aggregates the forecast details by forecast period, and sums up the fields configured here when creating each summary record. |
Skip Existing Forecast Series Date |
Y |
If enabled, does not show dates for which forecasts of the currently selected series already exist. |
