Fundamentals > Using the Calendar > Snoozing and Dismissing AlarmsWhen an alarm appears on your screen, you can dismiss it or snooze it. When you snooze it, you can specify how long the alarm will snooze for. An example of an alarm is shown in Figure 51. You can set one default alarm snooze time for all of the activities you create. This can be done in the User Preferences screen. See Setting Up Default Alarm Snooze Times. To snooze an alarm when it pops up
NOTE: If multiple alarms appear before you have a chance to either snooze or dismiss them, they are all queued behind the same alarm popup. You can click the Previous and Next buttons to move to each one. You can also click Dismiss All to dismiss every alarm that is currently active, or you can click Snooze All to defer every alarm that is currently active. |
Fundamentals |
