Siebel Hospitality Guide > Setting Up Charge Codes, Taxes, and Service Charges > Charge Code Administration >
Associating Charge Codes with Tax Codes
Perform the steps in the following procedure to associate a charge code with a tax code. This task is a step in Charge Code Administration. To associate a tax with a charge code
- Navigate to the Tax Service Admin screen > Charge Code List view.
- In the Charge Codes list, query for and select the required charge code.
- Click the Taxes view tab.
- In the Taxes list, click New.
- In the Add Taxes dialog box, select the tax you want to associate with the charge code, and click OK.
- Save the record.
The remaining fields are automatically populated with the property information. Repeat Step 4 and Step 5 for each service charge you want to associate with the charge code.
