Siebel Hospitality Guide > Defining Event Templates >
Adding Room Block Information
The following procedure details how to add room block information to both generic event templates and property-specific event templates. For more information about room block information, see Adding Room Block Information to an Event Opportunity.
This task is a step in Process of Creating Event Templates.
To add room block information to an event template
  1. Navigate to the Event Templates screen, and click the appropriate link:
    • To add room block information to a generic template, click the Generic Templates link.
    • To add room block information to a property-specific template, click the Property Specific Templates link.
  2. In the list, query for and select the required template.
  3. Click the link in the Name field, and then click the Room Block Info view tab.
  4. In the Room Block Info form, complete the fields and save the records. For more information about these fields, see Adding Room Block Information.
