Siebel Hospitality Guide > Working with Inventory > Checking Inventory Availability Using Property Screen Views > Reviewing Sleeping Room Type AvailabilityThe SR Type Availability view shows the availability information for a specified sleeping room type at a particular property. The availability numbers are broken down by room type and date. When users navigate to this view, they can see the sleeping room availability for the current date as well as for the next eight days. Using the Date form, users can query for different sleeping room types and date combinations to display the appropriate availability numbers. A Dates/Notes and a Go to Diary button are available in this view. See Reviewing Total Group Availability for more information on these buttons. This task is a step in Process of Working with Event Inventory. To review SR Type Availability
Navigating to the SR Type Availability ViewUsers can navigate to the Property SR Type Availability view by clicking the Room Type field in any Room Block Line item record in the Quotes Room Blocks view. Using this method, they navigate to the SR Type Availability view and see availability information beginning with the date assigned to the Room Block Line Item record. |
Siebel Hospitality Guide |
