Siebel Hospitality Guide > Working with Quote and Order Pricing > Function Space Pricing > Profit and Revenue ThresholdsThresholds are predetermined amounts that indicate how much profit needs to be made by the hospitality property to complete the booking. Some hospitality companies only accept function space business if a predetermined profit threshold amount is met for a property event. This mechanism is used to qualify event opportunities at a property based on the event's revenue and profit potential. The Revenue Manager can override the threshold and approve a quote even if it does not meet the threshold or has a negative threshold profit variance. Thresholds are defined by revenue managers for function space by days and day parts. For more information, see Function Space Pricing Administration. When thresholds are calculated, the following rules are applied:
Example of a Threshold Calculation with Applied RulesThis example explains the threshold calculation that occurs when three functions take place in the same function space called FSC 1. Table 27 shows the functions and time intervals. To calculate the required threshold for each function, the system determines the number of day parts the function covers. The day part is included even if the function only uses a few minutes of the day part. The system then determines the threshold associated with each of the day parts listed for the function. Table 28 shows how day parts are set up for the property.
Table 29 shows the thresholds that are in effect. The assumption is that function space category (FSC) 1 and 2 have the same threshold amount.
Table 30 shows how the required threshold calculation occurs, assuming the turntimes are zero. As can be seem from Table 30, the thresholds are calculated as follows:
The following exceptions may be applied when the required threshold is calculated:
Siebel Hospitality Guide |
