Siebel Hospitality Guide > Creating Hospitality Reports > About the Schedule of Events (SOE) Report >
Generating and Printing an SOE Report
Perform the steps in the following procedure to generate and print an SOE report.
This task is a step in Process of Generating Hospitality Reports.
To generate and print the SOE report
  1. Navigate to the Quotes screen > Quotes list view.
  2. From the toolbar, click the Reports button.
  3. In the Select a Report menu, click Schedule Of Events.
    The following table describes some of the fields in the SOE Report Parameters dialog box.
    Field
    Comments
    Quote Name
    The name of the quote for which the report is being generated.
    Function Space
    The name of the function space for which the report is being generated.
    Date
    The date for which the report is being generated. Any functions due to take place on this date are printed in the report.
    Print Line Items in SOE
    Selecting this check box indicates that line items should be included in the report.
  4. In the SOE Report Parameters dialog box, specify the appropriate report parameters and click Finish.
    The SOE report is generated in a Siebel Report Viewer window.
  5. Click the Print Setup button to display a standard Windows print dialog box.
  6. Choose appropriate printer settings, and then click OK.
Related Topics
