Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > Allowing Existing Fields to Be Used in Loyalty Promotion CriteriaYou can set up the application to allow you to use any field in the Member > More Info form in a criteria for a Loyalty promotion. For example, this would let you create promotions that only apply to members with two or more children. If you have configured transaction fields, as described in Allowing Additional Fields to Control Loyalty Points Given, then you can also use the method in this section to use transaction fields in Loyalty promotions. To allow member fields to be used in Loyalty promotion criteria
Siebel Loyalty Administration Guide |
