Siebel Object Interfaces Reference > Interfaces Reference > Business Component Methods > UndoRecord MethodUndoRecord reverses any uncommitted changes made to the record. This includes reversing uncommitted modifications to fields, as well as deleting an active record that has not yet been committed to the database. SyntaxReturnsUsageIf you are using UndoRecord to delete a new record, it is useful only after NewRecord has been called and before the new record has been committed. If you are using UndoRecord to reverse changes made to field values, it is useful only before the changes have been committed through a call to WriteRecord, or before the user has stepped off the record through the user interface. UndoRecord reverses uncommitted changes to a record. Therefore, if you wish to have a fine degree of control over which changes are reversed, place the code in the PreNewRecord, PreSetFieldValue, or PreWriteRecord event, and issue a CancelOperation to cancel the change invoked by the particular event. Used WithCOM Data Control, COM Data Server, Java Data Bean, Mobile Web Client Automation Server, Server Script See Also |
Siebel Object Interfaces Reference |
