Siebel Object Interfaces Reference > Interfaces Reference > Business Component Methods > WriteRecord MethodCommits to the database any changes made to the current record. SyntaxReturnsUsageAfter creating new records and assigning values to fields, call WriteRecord to commit the new record to the database. Used WithBrowser Script, COM Data Control, COM Data Server, Java Data Bean, Mobile Web Client Automation Server, Server Script ExampleThis Siebel VB example inserts an activity if the Sales Stage field is set to 02. For other examples, see GetMVGBusComp Method and NewRecord Method. (general) (declarations) Sub BusComp_SetFieldValue (FieldName As String) Select Case FieldName |
Siebel Object Interfaces Reference |
