Siebel Object Interfaces Reference > Interfaces Reference > Property Set Methods > PropertyExists MethodThis method returns a Boolean value indicating whether a specified property exists in a property set. SyntaxoPropSet.PropertyExists(propName) ReturnsIn Siebel VB, an integer (0 for false, 1 for true); in other interfaces, a Boolean UsageBecause GetProperty returns a null string ("") for every nonexistent property, use PropertyExists() in an if statement to determine whether a specific property has been set. Used WithBrowser Script, COM Data Control, COM Data Server, Java Data Bean, Mobile Web Client Automation Server, Server Script, Web Client Automation Server ExampleFor an example, read GetFirstProperty Method. |
Siebel Object Interfaces Reference |
