Siebel Object Interfaces Reference > Interfaces Reference > Property Set Methods > RemoveChild MethodThis method removes a child property set from a parent property set. SyntaxReturnsUsageWhen a child property set is removed, every child property set with an index higher than that of the removed set has its index decremented by 1. Used WithBrowser Script, COM Data Control, COM Data Server, Java Data Bean, Mobile Web Client Automation Server, Server Script, Web Client Automation Server ExampleThe following Siebel VB code fragment removes every child property set of a property set: Dim i As Integer See Also |
Siebel Object Interfaces Reference |
