Table 47. Application Methods Syntax Summary
ActiveBusObject Method |
Returns the business object for the business component of the active applet. |
Dim oApplication as Application Dim oBusObject as BusObject Set oBusObject = oApplication.ActiveBusObject
ActiveViewName Method |
Function that returns the name of the active view. |
Dim oApplication as Application Dim sView as String sView = oApplication.ActiveViewName
CurrencyCode Method |
Returns the three-letter operating currency code. |
Dim oApplication as Application Dim sCur as String sCur = oApplication.CurrencyCode
GetBusObject Method |
Instantiates and returns a new instance of the argument-specified business object. |
Dim oApplication as Application Dim oBusObject as BusObject set oBusObject = oApplication.GetBusObject busobject as String
GetProfileAttr Method |
Returns the value of an attribute in a user profile. |
Dim oApplication as Application Dim sAttr as String SAttr = oApplication.GetProfileAttr(name as String)
GetService Method |
Instantiates and returns a new instance of the argument-specified service. |
Dim oApplication as Application Dim oService as Service set oService = oApplication.GetService(serviceName as String)
GetSharedGlobal Method |
Gets the shared user-defined global variables. |
Dim oApplication as Application Dim sName as String sName = Application.GetSharedGlobal(varName as String)
GotoView Method |
Activates the named view and its business object. |
Dim oApplication as Application oApplication.GotoView viewName as String, [BusinessObjectName as BusObject]
InvokeMethod Method |
Calls the named specialized method. |
Dim oApplication as Application Dim sReturn as String sReturn = oApplication.InvokeMethod(methodName as String, methodArgs as String or StringArray)
LoginId Method |
Function that returns the login ID of the user who started the Siebel application. |
Dim oApplication as Application Dim sID as String iID = oApplication.LoginId
LoginName Method |
Function that returns the login name of the user who started the Siebel application. |
Dim oApplication as Application Dim sUser as String sUser = oApplication.LoginName
NewPropertySet Method |
Constructs and returns a new property set object. |
Dim oApplication as Application Dim oPropSet as ProperySet oPropSet = oApplication.NewPropertySet()
PositionId Method |
Function that returns the position ID that describes the user's current position. |
Dim oApplication as Application Dim sRow as String sRow = oApplication.PositionId
PositionName Method |
Function that returns the position name of the user's current position. |
Dim oApplication as Application Dim sPosition as String sPosition = oApplication.PositionName
RaiseError Method |
Raises a scripting error message to the browser. The error code is a canonical number. |
Dim oApplication as Application oApplication.RaiseError keyValue as String, parma1 as String, ...
RaiseErrorText Method |
Raises a scripting error message to the browser. The error text is the specified literal string. |
Dim oApplication as Application oApplication.RaiseErrorText message as String
SetPositionId Method |
Sets the active position to the position ID specified in the argument. |
Dim oApplication as Application oApplication.SetPositionId posId as string
SetPositionName Method |
Sets the active position to the position name specified in the argument. Returns a Boolean value indicating whether or not method succeeded. |
Dim oApplication as Application oApplication.SetPositionName posName as string
SetProfileAttr Method |
Used in personalization to assign values to attributes in a user profile. |
Dim oApplication as Application oApplication.SetProfileAttr name as String, value as String
SetSharedGlobal Method |
Sets a shared user-defined global variable. |
Dim oApplication as Application oApplication.SetSharedGlobal varName as String, value as String
Trace Method |
Appends a message to the trace file. |
Dim oApplication as Application oApplication.Trace message as String
TraceOff Method |
Turns off the tracing started by TraceOn. |
Dim oApplication as Application oApplication.TraceOff
TraceOn Method |
Turns tracing on. |
Dim oApplication as Application oApplication.TraceOn filename as String, type as String, selection as String
