Table 49. Business Component Methods Syntax Summary
ActivateField Method |
Allows queries to retrieve data for the specified field. |
Dim oBusComp as BusComp oBusComp.ActivateField fieldName as String
ActivateMultipleFields Method |
Allows queries to retrieve data for the fields specified in the property set. |
Dim oBusComp as BusComp oBusComp.ActivateMultipleFields oPropSet as PropertySet
Associate Method |
Creates a new many-to-many relationship for the parent object through an association business component. |
Dim oBusComp as BusComp oBusComp.Associate whereIndicator as Integer
BusObject Method |
Function that returns the business object that contains the business component. |
Dim oBusComp as BusComp Dim oBusObject as BusObject Set oBusObject = oBusComp.BusObject
ClearToQuery Method |
Clears the current query and sort specifications on the business component. |
Dim oBusComp as BusComp oBusComp.ClearToQuery
DeactivateFields Method |
Deactivates every currently activated field. |
Dim oBusComp as BusComp oBusComp.DeactivateFields
DeleteRecord Method |
Removes the current record from the business component. |
Dim oBusComp as BusComp oBusComp.DeleteRecord
ExecuteQuery Method |
Retrieves a set of BusComp records. |
Dim oBusComp as BusComp oBusComp.ExecuteQuery cursorMode as Integer
ExecuteQuery2 Method |
Dim oBusComp as BusComp oBusComp.ExecuteQuery2 cursorMode as Integer, ignoreMaxCursorSize as Integer
FirstRecord Method |
Moves to the first record in the business component. |
Dim oBusComp as BusComp Dim iIsRecord as Integer iIsRecord = oBusComp.FirstRecord
FirstSelected Method |
Moves the focus to the first record of the multiple selection in the business component. |
Dim oBusComp as BusComp Dim iIsMultipleSection as Integer iIsMultipleSelection = oBusComp.FirstSelected
GetAssocBusComp Method |
Function that returns the association business component. |
Dim oBusComp as BusComp Dim AssocBusComp as BusComp Set AssocBusComp = oBusComp.GetAssocBusComp
GetFieldValue Method |
Function that returns a value for the argument-specified field. |
Dim oBusComp as BusComp Dim sValue as String sValue = oBusComp.GetFieldValue(FieldName as String)
GetFormattedFieldValue Method |
Function that returns a formatted value for the argument-specified field. |
Dim oBusComp as BusComp Dim sValue as String sValue = oBusComp.GetFormattedFieldValue(FieldName as String)
GetMultipleFieldValues Method |
Returns a value for the fields specified in the property set. |
Dim oBusComp as BusComp oBusComp.GetMultipleFieldValues oFields as PropertySet, oValues as PropertySet
GetMVGBusComp Method |
Function that returns the MVG business component associated with the argument-specified field. |
Dim oBusComp as BusComp Dim MvgBusComp as BusComp set MvgBusComp = oBusComp.GetMVGBusComp(FieldName as String)
GetNamedSearch Method |
Function that returns the argument-named search specification. |
Dim oBusComp as BusComp Dim sValue as String sValue = oBusComp.GetNamedSearch(SearchName as String)
GetPicklistBusComp Method |
Function that returns the pick business component associated with the argument-specified field. |
Dim oBusComp as BusComp Dim pickBusComp as BusComp Set pickBusComp = oBusComp.GetPicklistBusComp(FieldName as String)
GetSearchExpr Method |
Function that returns the current search expression. |
Dim oBusComp as BusComp Dim sExpr as String sExpr = oBusComp.GetSearchExpr
GetSearchSpec Method |
Function that returns the current search specification for the argument-specified field. |
Dim oBusComp as BusComp Dim sSpec as String sSpec = oBusComp.GetSearchSpec(FieldName as String)
GetUserProperty Method |
Function that returns the value for an argument-specified property name. |
Dim oBusComp as BusComp Dim sValue as String sValue = oBusComp.GetUserProperty(propertyName as String)
GetViewMode Method |
Function that returns the visibility mode for the business component. |
Dim oBusComp as BusComp Dim iMode as Integer iMode = oBusComp.GetViewMode
InvokeMethod Method |
Calls the specialized method or user-created method specified in the argument. |
Dim oBusComp as BusComp Dim Return Return = oBusComp.InvokeMethod(methodName as String, methodArgs as String or StringArray)
LastRecord Method |
Moves to the last record in the business component. |
Dim oBusComp as BusComp Dim iReturn as Integer iReturn = oBusComp.LastRecord
Name Method |
Function that returns the name of the business component. |
Dim oBusComp as BusComp Dim sName as String sName = oBusComp.Name
NewRecord Method |
Adds a new record to the business component. |
Dim oBusComp as BusComp oBusComp.NewRecord(whereIndicator as Integer)
NextRecord Method |
Moves to the next record in the business component. |
Dim oBusComp as BusComp Dim iReturn as Integer iReturn = oBusComp.NextRecord
NextSelected Method |
Moves to the next record of the current multiple selection. |
Dim oBusComp as BusComp Dim iReturn as Integer iReturn = oBusComp.NextSelected
ParentBusComp Method |
Function that returns the parent business component. |
Dim oBusComp as BusComp Dim parentBusComp as BusComp Set parentBusComp = oBusComp.ParentBusComp
Pick Method |
Places the currently selected record in a picklist business component into the appropriate fields of the parent business component. |
Dim oBusComp as BusComp oBusComp.Pick
PreviousRecord Method |
Moves to the previous record in the business component. |
Dim oBusComp as BusComp Dim iReturn as Integer iReturn = oBusComp.PreviousRecord
RefineQuery Method |
Refines a query after a query has been executed. |
Dim oBusComp as BusComp oBusComp.RefineQuery
SetFieldValue Method |
Assigns a new value to the named field for the current row of the business component. |
Dim oBusComp as BusComp oBusComp.SetFieldValue FieldName as String, FieldValue as String
SetFormattedFieldValue Method |
Accepts the field value in the current local format and assigns the new value to the named field for the current row of the business component. |
Dim oBusComp as BusComp oBusComp.SetFormattedFieldValue FieldName as String, FieldValue as String
SetMultipleFieldValues Method |
Assigns a new value to the fields specified in the property set for the current row of the business component. |
Dim oBusComp as BusComp oBusComp.SetMultipleFieldValues oPropSet as PropertySet
SetNamedSearch Method |
Sets a named search specification on the business component. |
Dim oBusComp as BusComp oBusComp.SetNamedSearch searchName as String, searchSpec as String
SetSearchExpr Method |
Sets the entire search expression for the business component. |
Dim oBusComp as BusComp oBusComp.SetSearchExpr searchSpec as String
SetSearchSpec Method |
Sets the search specification for the specified field. |
Dim oBusComp as BusComp oBusComp.SetSearchSpec fieldName as String, searchSpec as String )
SetSortSpec Method |
Sets the sort specification for a query. |
Dim oBusComp as BusComp oBusComp.SetSortSpec sortSpec as String
SetUserProperty Method |
Sets the value of the specified User Property. |
Dim oBusComp as BusComp oBusComp.SetUserProperty propertyName as String, newValue as String
SetViewMode Method |
Sets the visibility type for the business component. |
Dim oBusComp as BusComp oBusComp.SetViewMode viewMode as Integer
UndoRecord Method |
Reverses any uncommitted changes made to the record. |
Dim oBusComp as BusComp oBusComp.UndoRecord
WriteRecord Method |
Commits to the database any changes made to the current record. |
Dim oBusComp as BusComp oBusComp.WriteRecord
