Siebel Order Management Guide Addendum for Industry Applications > Workflows for Partner Asset-Based Ordering >
CUT eChannel - Goto Product Catalog View
If the user has been identified as a Standard Partner Commerce user, this workflow displays the product catalog used for Standard Partner Commerce, which allows the user to browse eCatalog, select products, and add products to the shopping cart.
This workflow is shown in Figure 19.
Figure 19. CUT eChannel - Goto Product Catalog View Business Process
Workflow Description. This workflow does the following:
Siebel Order Management Guide Addendum for Industry Applications Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices.
