Siebel Order Management Infrastructure Guide > Signals > Creating Signal Actions > Modifying Signal Properties for Signal ActionsSignal properties are similar to user properties on repository objects. Signal properties are name/value pairs used to configure processing. In this release, the only supported use of signal properties is to provide a CanInvoke check. To modify signal properties for a CanInvoke check
Example of Signal Properties Settings for a CanInvoke CheckAn example of fields set for a CanInvoke check are listed in Table 5. NOTE: If CanInvoke logic exists for a specific Mode, it overwrites the CanInvoke logic defined for the mode Any. In the example above, using Quote mode, the CanInvoke logic used will be [Status] = LookupValue('ORDER_STATUS', 'Open') instead of [Account Id] is not null. |
Siebel Order Management Infrastructure Guide | Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
