Pricing Administration Guide > Creating Product Promotions > Process of Creating Product Promotions >
Customizing Recommendation Messages for Product Promotions
By default, if the application recommends a promotion, it displays a message in the following form:
Recommend promotion '[Prod Prom Name]': [Promotion Description].
You can customize the form of this message.
To customize the recommendation message for product promotions
  1. Navigate to the Administration - Application screen and in the link bar, click Message Types.
  2. In the All Message Types list, query to find the record with the name Promotion - Bottomup Recommendation.
  3. In the Message Type view, enter the desired message in the Full Text field.
