Pricing Administration Guide > Creating Product Promotions > Process of Creating Product Promotions >
Creating Translations of Recommendation Messages for Product Promotions
You can translate the recommendation message in multiple languages. The language that is displayed depends on the language of the user's application.
This task is a step in Process of Creating Product Promotions.
To specify recommendation messages for a product promotion
  1. Navigate to the Administration - Product screen > Product Promotions view.
  2. In the Product Promotions list, select the promotion.
  3. Click the Messaging view tab.
  4. For each language in which the message will be displayed, add a record to the Messaging list and complete the necessary fields. Some fields are described in the following table.
    Field
    Comments
    Language Name
    This field displays the name of the language after you select the language code.
    Language Code
    Select the language code—for example, select ENU for American English or ENG for British English.
    Description
    Enter the text of the recommendation message in the appropriate language.
