Siebel Remote and Replication Manager Administration Guide > Implementing Siebel Remote Server >
Starting Siebel Remote Server Components
Use Siebel Server Manager to set values for start-up parameters for the following Siebel Remote server components:
The default parameter values for each component are described in the following sections.
The following procedures describe how to configure these server components.
To start Transaction Processor - srvrmgr command line
  • From the srvrmgr command line, enter the following command all on one line:
    start task for comp txnproc server <server_name> with <parameter1>= <value1>, <parameter2=<value2>,...
    Values are from Start-Up Parameters for Transaction Processor.
    NOTE:  When logging into srvrmgr command line, indicate the server name. Otherwise srvrmgr will default to the Enterprise Server. For details regarding the Server Manager command-line interface, see Siebel System Administration Guide.
To start Transaction Processor - GUI
  • In Siebel 7, the Transaction Processor cannot be started manually through the GUI Server Manager unless the Siebel Server is up and running. The component has been defined to start one task when the Siebel Server is started if the component is enabled. If the component is not started, from the application-level menu, choose Navigate > Site Map > Administration - Server Management > Servers > Component Group, select the Siebel Remote component group, select the Transaction Processor component, and click Startup. A new task should start automatically.
To start Transaction Router - srvrmgr command line
To start Transaction Router - GUI
  • In Siebel 7, the Transaction Router cannot be started manually through the GUI Server Manager unless the Siebel Server is up and running. The component has been defined to start at least one task when the Siebel Server is started if the component is enabled. If the component is not started, from the application-level menu, choose Navigate > Site Map > Administration - Server Management > Servers > Component Group, select the Siebel Remote component group, select the Transaction Router component, and click Startup. A new task should start automatically.
To start Transaction Merger - srvrmgr command line
    start task for comp txnmerge server <server_name> with <parameter>=<value>,<parameter2>=<value2>,...
    Values are from Start-Up Parameters for Transaction Merger.
To configure Transaction Merger - GUI
  • In Siebel 7, the Transaction Merger cannot be started manually through the GUI Server Manager unless the Siebel Server is up and running. The component has been defined to start at least one task when the Siebel Server is started if the component is enabled. If the component is not started, from the application-level menu, choose Navigate > Site Map > Administration - Server Management > Servers > Component Group, select the Siebel Remote component group, select the Transaction Merger component, and click Startup. A new task should start automatically.
To configure Synchronization Manager - srvrmgr command line
  • Synchronization Manager is started automatically by the Siebel Server using the default configuration. It does not need an explicit configuration. For information on using Siebel Server Manager to manage and administer server components, see Siebel System Administration Guide.
