Siebel Remote and Replication Manager Administration Guide > Implementing Siebel Remote Server > Starting Siebel Remote Server Components >
Transaction Merger
Table 8 shows selected parameters for the Transaction Merger.
Table 8. Start-Up Parameters for Transaction Merger
Default Value and Usage Notes |
Error Mode |
ErrorMode |
Optional |
Determines how database errors are handled during a Transaction Merger process. Default is STOP. Available modes include:
- STOP. Stops Transaction Merger.
- IGNORE. Causes Transaction Merger to sleep if all nodes were ignored in an iteration.
- DISABLE_NODE. Disables all nodes and stops Transaction Merger if an error recurs in the same row.
If the mode is set to DISABLE_NODE, Transaction Merger sets the effective end dates of clients with errors to the current time. You then need to reextract the Mobile Web Clients to reactivate them.
Sleep Time |
SleepTime |
Optional |
Time to sleep between iterations (in seconds). Default is 60. |
