Table 6. Start-Up Parameters for Transaction Processor
Comments and Default Value |
Sleep Time |
SleepTime |
Optional |
Time (in seconds) to sleep between iterations. When it wakes up, it will process transactions. The default is 60. |
Maximum Reads per Iteration |
MaxRead |
Optional |
Maximum number of operations to read per run. The default value is 0, which means it will read all outstanding operations in the Master Transaction Log. |
Clean txns iterations |
CleanTxnsIter |
Optional |
Sets frequency for Txn Processor to delete txns from server database master txn log table. This parameter is specified in the number of iterations. Default is 10. |
Clean .dx files iterations |
CleanFilesIter |
Optional |
Sets frequency for Txn Processor to delete DX files from the Siebel server's DOCKING\TXNPROC directory. The default is 1 iteration, default of 60 seconds per iteration as shown in SleepTime parameter. |
Write compressed .dx files |
WriteCompressed |
Optional |
Writes DX files in compressed format. Default is FALSE and should not be changed unless advised by Siebel Technical Support or Siebel Expert Services. |
TS Block Size |
TSBlockSize |
Optional |
Block size for dobjinst.dbf (visibility database) in bytes. Data is stored blocks. The block size here is different from Operating System block size. It is determined during dbxtract for a Mobile Web Client. The default is 4096 bytes. Please do not modify this parameter without approval from Expert Services or Technical Support. |
TS Cache Size |
TSCacheSize |
Optional |
Cache size for dobjinst.dbf (visibility database) in kilobytes. The default is 4096 kilobytes. Please do not modify this parameter without approval from Expert Services or Technical Support. |
TS DB Recreate |
TSDbRecreate |
Optional |
The default value is FALSE. If the parameter is set to TRUE, Txnproc will recreate its dobjinst.dbf (visibility database). It is necessary to do this because an older dobjinst.dbf database (file system recovery) will mismatch with the server database. The new one resolves the mismatch. |
