Siebel Remote and Replication Manager Administration Guide > Implementing Siebel Replication Manager > Installing a New Enterprise Server > Installing the Siebel Name ServerThe Siebel Name Server includes a persistent store for configuration parameters and run-time information. The Name Server is part of the logical entity called Siebel Gateway. Each Siebel Server accesses the Name Server at start-up and periodically throughout its operation. Consequently, there must be a reliable network connection to the Name Server. For this reason, it is strongly recommended that you install a Name Server local to your Regional Node. For more information about installing the Siebel Name Server, see the Siebel Server installation guide for the operating system you are using. This server must be installed and running before you can proceed with the remainder of the Regional Node installation. For more information on the Siebel Name Server and Siebel Server, see Siebel System Administration Guide. |
Siebel Remote and Replication Manager Administration Guide |
