Siebel Remote and Replication Manager Administration Guide >
Implementing Siebel Replication Manager
This chapter describes the instructions and procedures for implementing Siebel Replication Manager. Before you proceed with the implementation, you must completely install and test the Siebel Database Server, Siebel Server or Servers, and Siebel File System in the Headquarters Node.
For instructions on completing these tasks, see the Siebel Server installation guide for the operating system you are using.
As an overview, to implement each Regional Node you must implement four main phases:
  • Install a new Enterprise Server
  • Define the Regional Node
  • Extract the Regional Database
  • Initialize the Regional Database
Table 26 shows the tasks for Implementing Replication Manager.
Table 26.  Tasks for Implementing Siebel Replication Manager
Task
Where Performed
Installing a New Enterprise Server
New Server
Installing the Siebel Name Server
New Server
Installing the Siebel Server
New Server
Installing the Siebel Database Server
New Server
Installing the Siebel File System
New Regional File Server
Defining the Regional Node
Parent Node
Registering a Regional Node
Parent Node
Adding Mobile Users to the Regional Node
Parent Node
Extracting the Regional Database
Parent Server
Initializing the Regional Database
New Server
Configuring Regional Node for Mobile Web Clients
New Server
Starting Replication Agent
Regional Node
Setting Up Additional Application Servers on Regional Nodes
New Server
