Siebel Remote and Replication Manager Administration Guide > Implementing Siebel Replication Manager > Installing a New Enterprise Server > Installing the Siebel ServerEach Regional Node must have at least one Siebel server, which is used to synchronize the Regional Node with its parent. This Siebel Server may also support Siebel Remote mobile users. Depending on the number of users and applications to be supported, additional Siebel Servers may be required. Before you install the Regional Siebel Server, you may first need to install the correct ODBC driver for the RDBMS vendor. For an Oracle RDBMS, you do not need to install an ODBC driver. For other supported RDBMS vendors, you must install an ODBC driver. For the name of the required ODBC driver and version information, see the system requirements and supported platforms documentation for your Siebel application. System requirements and supported platforms documentation for all Siebel applications can be found on Siebel SupportWeb at http://ebusiness.siebel.com/supportweb/. For instructions on installing the Siebel Server, see the Siebel Server installation guide for the operating system you are using. When prompted by the Siebel Server installation program, be certain to specify the correct connectivity information for the Siebel Name Server, Siebel File System, and Siebel Database Server on the Regional Node. Each Regional Node should have a unique Enterprise Server name associated with it. |
Siebel Remote and Replication Manager Administration Guide |
