This chapter is written for system administrators who install the Siebel Database Server on a Siebel Server, and for database administrators who perform related tasks on the RDBMS. It includes the following topics:
CAUTION: In an upgrade environment, you install the module called the Siebel Database Server on the Siebel Server, following the procedure in Installing the Siebel Database Server on the Siebel Server, but you do not perform any other tasks mentioned in this chapter. For more information, see About Installing in Upgrade Environments.
NOTE: If your database is IBM DB2 UDB for z/OS, refer to Implementing Siebel Business Applications on DB2 UDB for z/OS instead of this chapter. See also the relevant information under Planning RDBMS Installation and Configuration.
