Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools > Installing Siebel EAI Connector Software > Preinstallation Considerations for EAI ConnectorsAdditional configuration is required if you plan to use Siebel Connector for Oracle Applications against multiple instances of the Oracle back-office application. Please contact Siebel Technical Support for configuration instructions. NOTE: Siebel Connector for Oracle Applications supports all Siebel 7 operating systems. For list of supported platforms, see System Requirements and Supported Platforms on Siebel SupportWeb. |
Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools |
