Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools > Installing the Siebel Web Server Extension > Postinstallation Tasks for the SWSE >
Configuring the Default HTTP and HTTPS Ports for the Web Server
The default HTTP and HTTPS ports for the Web server are port 80 and 443, respectively. When you deploy SWSE onto a third-party Web server, you might want to configure these to use a different port numbers. The following procedure provides the steps to configure these ports. To configure the default ports for HTTP and HTTPS
- Open the eapps.cfg file.
- Locate the
[defaults] section.
- Change the port number for
HTTPPort and HTTPSPort to a desired port number.
HTTPPort = 81 HTTPSPort = 444
- Configure the Web server.
HTTP port for both IBM HTTP Server and HP Apache Web Server
- Using any text editor, open the SWSE_ROOT/conf/httpd.conf file.
- Locate the
Listen section and change the HTTP port number to the number you set in Step 3.
Listen HostIP :81
where:
- HostIP = The IP Address of the Web server
- Change the
ServerName value to the same value as the one for Listen .
ServerName HostIP :81
HTTPS port for HP Apache Web Server
- Using any text editor, open the SWSE_ROOT/conf/ssl.conf file.
- Change the HTTPS port numbers in the following section to the port number you set in Step 3.
Listen 444 <VirtualHost_default_:444> SSLEngine on
HTTPS port for IBM HTTP Server
- Add the following section before the Virtual Directories section to enable SSL.
LoadModule ibm_ssl_module modules/mod_ibm_ssl.so Listen HostIP :444
where:
- Add the following section at the end of the httpd.conf file, before the Virtual Directories section.
<VirtualHost HostIP :444> SSLEnable DocumentRoot $home/$build/web/htdocs/en_US ErrorLog logs/ssl_error_log CustomLog logs/ssl_access_log common
</VirtualHost> Keyfile $home/$build/web/ssl/key.kdb
Sun Java System Web Server
- Using the Sun Java System Web Server Admin console, go to the Preferences screen.
- Click on the Edit Listen Sockets tab and change the port number to the new value you set in Step 3.
