Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools > Installing Siebel Mobile Web Clients > Siebel Client Shortcuts and Start-Up Options >
The Siebel client and Sample Database installers create shortcuts in the Siebel program folder for the modules you have installed. For Siebel applications, separate shortcuts are installed for each installed language. Which shortcuts are installed depends on your installation choices and is also subject to the settings in the siebel.ini file. Most shortcuts are installed in the program group; some are installed in the start-up group. For information about customizing the shortcuts, see Siebel Client Start-Up Options. Siebel application shortcuts installed by the client installer are listed here. When you run a shortcut to start a Siebel application, you can connect to the Siebel Database (for LAN-connected users of the Siebel Developer Web Client), to an initialized local database on the local machine (for Mobile Web Client), or to the Sample Database on the local machine (if it has been installed). The Demo application shortcuts connect to the Sample Database using predefined demonstration users. Each application shortcut loads the Siebel configuration file for that application—for example, Siebel Call Center uses the file uagent.cfg. Siebel Application Shortcuts
The following are the Siebel application shortcuts installed in the Siebel client program group:
- Siebel Call Center. Starts Siebel Call Center.
- Siebel Call Center Demo. Starts Siebel Call Center, using the Sample Database.
- Siebel Employee Relationship Management Administration. Starts Siebel Employee Relationship Management Administration.
- Siebel Employee Relationship Management. Starts Siebel Employee Relationship Management.
- Siebel Employee Relationship Management Demo. Starts Siebel Employee Relationship Management, using the Sample Database.
- Siebel Marketing. Starts Siebel Marketing.
- Siebel Marketing Demo. Starts Siebel Marketing, using the Sample Database.
- Siebel Partner Manager. Starts Siebel Partner Manager.
- Siebel Partner Manager Demo. Starts Siebel Partner Manager, using the Sample Database.
- Siebel Partner Portal. Starts Siebel Partner Portal.
- Siebel Sales. Starts Siebel Sales.
- Siebel Sales Demo. Starts Siebel Sales, using the Sample Database.
- Siebel Service. Starts Siebel Service.
- Siebel Service Demo. Starts Siebel Service, using the Sample Database.
Utility and Synchronization Program Shortcuts
The following are additional shortcuts installed in the Siebel client program group. These shortcuts run utilities such as Siebel Packager or synchronization programs.
- Siebel Packager. Starts the Siebel Packager utility. For more information, see Going Live with Siebel Business Applications.
- Siebel Patch Utility. Starts the Siebel Patch utility (siebpatch.exe). For more information, see the Siebel Anywhere Administration Guide.
- Siebel Remote. Starts the Siebel Remote stand-alone synchronization program (siebsync.exe). For more information, see the Siebel Remote and Replication Manager Administration Guide.
- Siebel TrickleSync. Starts the Siebel TrickleSync program (autosync.exe). This shortcut is created in both the program group and the start-up group. For more information, see the Siebel Remote and Replication Manager Administration Guide.
- Siebel Sales Handheld Sync. Starts the Siebel Sales Handheld Sync synchronization program (syncmanager.exe).
- Siebel Service Handheld Sync. Starts the Siebel Service Handheld Sync synchronization program (syncmanager.exe).
- Siebel QuickStart. Starts the Siebel QuickStart agent, for Siebel Mobile Web Client users. For more information, see Using Siebel QuickStart with the Siebel Mobile Web Client.
NOTE: The Siebel QuickStart shortcut is not installed by default. To install it, specify QuickStart = YES in the [Icons] section of the siebel.ini file. The shortcut is created according to the settings in the [QuickStart] section of the file. The shortcut is installed in the start-up group when Folder = startup. The shortcut must be located in the start-up group to function correctly.
