Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools > Installing the Siebel Server > Managing Environment VariablesThere are several environment variables that must be properly set for optimal functioning of the Siebel Server, as shown in Table 18. These include: NOTE: For information on tuning the UNIX kernel and other parameters for Siebel Server optimization, see the Performance Tuning Guide.
The Siebel environment variables $SIEBEL_HOME and $SIEBEL_ROOT must be set to enable execution of the Siebel Gateway Name Server and Siebel Server management utilities documented in the Siebel System Administration Guide. During Siebel Gateway Name Server and Siebel Server installation and configuration, the script files siebenv.csh (for the C shell and its variants) and siebenv.sh (for the Bourne and Korn shells and their variants) are automatically created in the $SIEBEL_HOME directory. When sourced, these shell scripts set the environment variables. If you have configured your Siebel Server to start manually, you must source siebenv.* before starting the server. For this reason, you may want to add a call to the appropriate siebenv.* script to the logon files of all Siebel administrator UNIX accounts, so that these variables are set automatically whenever a Siebel administrator logs on. NOTE: If you want to change the default settings of these environment variables, you must do so before you start the Siebel Server. UNIX Tuning for Siebel ApplicationsThere are several UNIX system environment variables you must set for proper functioning of the Siebel Server. For detailed information on tuning the UNIX kernel and other tunable parameters for Siebel Server optimization, see the Performance Tuning Guide. See also Siebel Server Installation Requirements, Specifying the Locale for Siebel Applications, and Specifying the Locale for Your UNIX Operating System. |
Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools |
