Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools > Configuring the RDBMS > Configuring IBM DB2 UDB for Siebel Applications > Guidelines for Preventing DB2 UDB from Running Out of ODBC Statement HandlesIBM DB2 UDB can quickly run out of ODBC statement handles, depending on the number of business objects your enterprise uses. Because it is difficult to know how many business objects your users actually use, you should increase this number automatically each time you install the DB2 UDB client, or when rebinding database utilities. Increase the number of CLI packages to 6 by rebinding the CLI packages, using the special DB2
For more information about the DB2 bind command and the |
Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools |
