Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools > Configuring the RDBMS > Configuring IBM DB2 UDB for Siebel Applications >
Guidelines for Setting DB2 UDB Database Manager Configuration Parameters
You can set the database configuration parameters using the update database manager configuration command of the DB2 Command Line Processor or using the DB2 Control Center. For more information on modifying these configuration parameters, see the IBM DB2 UDB technical documentation. Table 6 describes DB2 UDB database manager configuration parameters that differ from the default settings. Set these parameters for each DB2 UDB instance. Use the configuration information in Table 6 for the listed parameters. For parameters not listed in this table, accept the default settings.
Table 6. DB2 UDB Database Manager Configuration Parameters
SHEAPTHRES
Sort heap threshold (4 KB) |
200000
Deployments with 3,000 or more concurrent users and using over 5 GB of RAM can increase this to 300000 . |
DIR_CACHE
Directory cache support |
YES
ASLHEAPSZ
Application support layer heap size |
15
RQRIOBLK
Maximum requester I/O block size (bytes) |
65535
MON_HEAP_SZ
Database monitor heap size (4 KB) |
128 (minimum)
QUERY_HEAP_SZ
Query heap size (4 KB) |
16384
KEEPFENCED
Keep Fenced process |
YES
MAXAGENTS
Maximum number existing agents |
20000 (minimum)
NUM_INITAGENTS
Initial number agents in pool |
10
NUM_POOLAGENTS
Number of agents in the agent pool kept active at all times |
80
MAX_COORDAGENTS
Maximum number coordinating agents |
MAXAGENTS
INDEXREC
Index re-creation time |
RESTART
INTRA_PARALLEL
Enable intra-partition parallelism |
NO
DB2set Parameters
Use the db2set command to set the parameters (for example, db2set DB2_HASH_JOIN = NO ) referenced in Table 7.
Table 7. db2set Parameters
DB2MEMDISCLAIM
AIX only. When set to YES, DB2 agents explicitly request that the database server disassociate the reserved paging space from freed memory. Affects how DB2 frees shared memory. |
YES |
DB2MEMMAXFREE
AIX only. Maximum amount of unused memory in bytes retained by DB2 processes. It affects how DB2 frees shared memory and causes DB2 to release memory as soon as the size of the DB2 agent goes above the listed value. |
1000000 |
DB2_HASH_JOIN
Turns off hash joins in the optimizer. |
NO |
DB2_MMAP_WRITE
AIX only. Recommended setting only; you should evaluate this setting for your particular configuration and environment. |
OFF |
DB2_MMAP_READ
OFF |
DB2_CORRELATED_PREDICATES
When set to YES, the optimizer is able to determine whether predicates in a query are related, which permits DB2 to calculate the filter factor more accurately. |
YES |
DB2_PIPELINED_PLANS
Tells the DB2 optimizer to favor pipeline execution plans—plans that are left deep and have no temporary result sets. |
ON |
DB2_INTERESTING_KEYS
Limits the number of execution plans generated by the DB2 optimizer. |
ON |
DB2_PARALLEL_IO
Useful when using RAID devices. For more information, see your DB2 vendor documentation. |
DB2_STRIPED_CONTAINERS
ON |
EXTSHM
AIX only. Use this parameter only when you have the Siebel Database and the Siebel Server on the same AIX machine. EXTSHM must be set when the DB2 UDB database is created and must be included in the script that starts it. The parameter also must appear in the sqllib/db2profile file for the DB2 UDB server.
Additionally, you should include this parameter in the script that starts the DB2 client. After changing any of these settings, you must perform a db2stop , then db2start , to implement the changes in your DB2 UDB database. |
ON |
DB2ENVLIST
AIX only. When starting a DB2 UDB server and running EXTSHM , EXTSHM must be part of the DB2 environment. This parameter must be set when the database is created. |
EXTSHM |
DB2_NO_PKG_LOCK
To bind the Siebel package with siebbind , this package must be off. |
OFF |
