Table 31. Siebel Client Application Parameters
AccessDir
Specifies the directory where Microsoft Access is installed. |
ApplicationName
Name of the application object in the repository to use, such as Siebel Sales or Siebel Service. ApplicationName determines which splash screen appears and which set of menus is enabled. |
ApplicationSplashText
Text that appears on a splash screen when starting up a Siebel application. The default varies by the application. If you are starting Siebel Sales, for example, ApplicationSplashText is set to Siebel Sales by default. |
ApplicationTitle
Changing the text in the ApplicationTitle parameter in the configuration file changes the Application Title value in the multi-value group applets and the Title that appears on the left side of the application title bar. As necessary, make this change in the appropriate configuration file for the intended application. For example, for Siebel Call Center, this parameter would be set, in the file uagent.cfg, to Siebel Call Center. |
CaptionPrefix
Allows customizing of the title in the upper left corner of the Siebel client application. Reads Siebel by default. |
ClientRootDir
Specifies the directory where the Siebel client software is installed. |
ComponentName
Specifies the Siebel Anywhere configuration that should be used during version check. Navigate to the Siebel Anywhere Administration > Configurations view to see the configurations. Change the setting for this parameter if you want this configuration file to be version-checked by a specific Siebel Anywhere configuration. For example, if you want to version-check the Siebel software used at one facility separately from the software used at another facility, create two Siebel Anywhere configurations appropriately named. Then, in the configuration file for each set of users, enter a different value for the ComponentName parameter. It is recommended that you use only alphanumeric characters plus dashes and normal parentheses for the ComponentName parameter. If you want to use the Priority upgrade feature, the maximum character length for the Upgrade Component name should be 40. |
DataSource
Name of the default data source that appears in the Connect to drop-down list in the Siebel login screen. Must correspond to an existing data source defined in the configuration file. By default, this parameter is set to Local. |
DefaultChartFont
Font name specification for chart applets. Defaults to Arial-10 normal. |
DockRepositoryName
Allows the application to read repository information straight from the database, rather than from the Siebel repository file (SRF) file. The value should match the repository used for compiling the SRF file. |
EnableOLEAutomation
TRUE or FALSE. Enables OLE interfaces. This parameter must be set to TRUE (the default) in order for the Siebel Mobile Web Client to generate reports locally. |
EnablePersonalization
Must be set to TRUE to activate the personalization (content targeting) functionality. Siebel workflow processes will not execute properly until personalization events are reloaded. |
EnableScripting
TRUE or FALSE. Enables use of Siebel Visual Basic or Siebel eScript. Setting this parameter to false also disables browser scripts in addition to server scripts. |
LocalDbODBCDataSource
Name of the ODBC data source that is set up to access the local database. It is used by a variety of features in the Siebel Business Applications and in Siebel Tools. It should not need to be modified because it is correctly configured by the installation program. |
MultiCurrency
TRUE or FALSE. Enables multicurrency support. |
OLEAutomationDLL
Name of the DLL file that implements OLE interfaces. |
OLEMessagePendingDelay
Controls the amount of time that the Siebel application waits for an OLE server to respond to a request before a timeout message appears: Server not responding ...
This parameter should be set in milliseconds, contained within quotation marks. For example, for 15 seconds, set OLEMessagePendingDelay to 15000. The default setting is eight seconds (8000). You may want to increase the timeout on slow computers so that the timeout message does not appear as frequently. |
PersonalizationLog
Add the following to the configuration file to view a log of all personalization activity: PersonalizationLog = "C:\personalization.txt"
where C: is the drive where you want to store the log. The log may assist in the process of debugging your rules, events, and actions. |
RemoteSearchServer
TRUE or FALSE. TRUE indicates that searches are performed on a remote machine; FALSE indicates that searches are performed on a local machine. |
RemoteSearchServerPath
Indicates the name of the remote machine that performs searches. |
ReportsDir
Directory where reports are installed. It is typically left blank. |
ReportsODBCDataSource
Name of ODBC data source used to connect to modules such as Crystal Reports. |
RepositoryFile
Name of the Siebel SRF file to use. RepositoryFile is the physical file that contains all runtime object definitions.
ScriptingDLL
Name of the shared library that implements Siebel Visual Basic or Siebel eScript. If the Siebel Server runs on a UNIX server machine, and you plan to use eScript, set the value of ScriptingDLL to sscfjs.so. |
SearchDefName
Search definition from Siebel Tools to be used for searching. |
SearchEngine
Defines the search engine to be used for searching. Currently, only Hummingbird SearchServer is supported, for which this parameter should be set to Fulcrum. |
SearchInstallDir
File location of the Hummingbird SearchServer installation. Example: C:\Program Files\Fulcrum. |
SharedModeUsersDir
Directory where user preference files are stored. It is typically left blank, otherwise it must be set to a directory under a network shared drive, but it cannot be set to the shared drive itself. For example, if \\yourserver\common is the network shared drive, you cannot set SharedModeUsersDir to \\yourserver\common. Instead, set SharedModeUsersDir to a directory under \common. |
TempDir
Directory where temporary files should be created. |
Version
Represents version of file. This parameter is for internal use only and is automatically maintained by Siebel Anywhere. When you create an upgrade kit for the configuration file, Siebel Anywhere increments this version string appropriately, based on the version information from the Upgrade Components screen. NOTE: When you perform a Siebel Anywhere upgrade, you must manually upgrade files from the upgraded Siebel client directory to the Siebel Server directory.
