Table 33. Data Source Parameters
AutoStopDB
TRUE or FALSE. Applies to Sample or Local data sources only. If TRUE, then the SQL Anywhere database engine exits when the user logs out. If FALSE (the default), then the database engine continues to run after the user logs out of the Siebel applications. Regarding the local database, see also Siebel Remote and Replication Manager Administration Guide. |
CaseInsensitive
TRUE or FALSE. If TRUE, notifies the client to work with the database in case-insensitive mode. See also the description of the InsensitivityFactor parameter for data sources. NOTE: Queries against fields of type DTYPE_ID are always case-sensitive, even if the CaseInsensitive parameter is set to TRUE. For more information, see Applications Administration Guide.
ConnectString
Database-dependent string that defines how to connect to the database. For SQL Anywhere (for local database or Sample Database), the -q option hides the SQL Anywhere icon. The -c option indicates the initial cache size, and -ch indicates the limit of the cache size. The -m option indicates to the SQL Anywhere database engine to truncate the transaction log after each checkpoint. The ConnectString parameter is also used to specify the Gateway Name Server machine in the GatewayDataSrc section. In the Siebel Mobile Web Client's configuration file, you must specify the Gateway Name Server's hostname, preferably in a fully qualified form like node.domain.xxx. Failure to specify this parameter correctly results in the Server Administration screens not being accessible. For more information on using connect strings for different server databases, see the Siebel Installation Guide for the operating system you are using. |
ContactLogin
TRUE or FALSE. If TRUE, indicates that the corresponding data source uses contact login, rather than employee login. Because a contact user is generally not associated one-to-one with a database account, you must use a security adapter to support contact users. If FALSE, the data source is using employee login, rather than contact login. |
DLL
Name of the DLL file to use for the database connector code. The names differ depending upon whether you are using Oracle, SQL Server, DB2, and so on. |
DockConnString
Name of the docking server (Siebel Remote Server). It is the machine name of the Siebel Server against which the Mobile Web Client synchronizes. |
DockRecvTxnsPerCommit
Number of transactions received by the Mobile Web Client before a commit is issued to the database. The default value for this parameter is 10. Change the setting to:
- A higher value if you have a fast network connection, such as a LAN. Increasing the value can provide better performance when synchronizing the Mobile Web Client with the server.
- A lower value if you have a lower-bandwidth network connection, such as a modem.
DockTxnsPerCommit
Number of transactions processed before a commit is issued to the database. |
EnterpriseServer
Name of the Siebel Enterprise Server. |
FileSystem
Specifies how the Mobile or Siebel Developer Web Client (for administrative purposes) accesses the Siebel File System. The maximum length of this parameter is 100 characters. Generally, FileSystem and other parameters identified below are set during the Siebel client installation. Mobile Web Client. The following scenario for setting the FileSystem parameter applies to the Siebel Mobile Web Client. The Siebel File System should be installed locally on a Mobile Web Client, so that it is accessible when the client is not connected to the network and can be synchronized using Siebel Remote.
Developer Web Client. The following scenarios for setting the FileSystem parameter apply to the Siebel Developer Web Client when used for administrative purposes. Make sure that users on the Siebel Developer Web Client have physical access privileges for the Siebel File System directories.
NOTE: If your networked Siebel File System resides on a UNIX server, you require a cross-platform NFS file system mounting tool to connect from Siebel Developer Web Clients running on Windows machines.
The system administrator must manually create the att subdirectory in the Siebel File System. If there is an existing File System installation, the administrator must move all file attachments from FS_location to FS_location\att. |
GatewayAddress
Virtual IP address of the Siebel Gateway. |
Hidden
TRUE or FALSE. Determines if the data source shows up in the login screen's picklist of data sources. |
InsensitivityFactor
Set to a positive integer value (default is 2). Applies only when the CaseInsensitive parameter is TRUE for the data source. The value controls the number of characters in each string that are treated as case-insensitive in a query. Not all database vendors support case-insensitivity efficiently, so this feature provides an approximate solution. See also the description of the CaseInsensitive parameter for data sources. Below is an example of the SQL WHERE clause generated when searching for an opportunity named New, when InsensitivityFactor is set to 2. WHERE
((S_OPTY.NAME LIKE 'ne%' OR
S_OPTY.NAME LIKE 'Ne%'OR
S_OPTY.NAME LIKE 'nE%'OR
S_OPTY.NAME LIKE 'NE%')
AND
UPPER(S_OPTY.NAME)=UPPER('New'))
The above example shows that all permutations of the first two letters of the string 'New' are checked. With a higher factor, the number of permutations grows exponentially, and performance suffers. NOTE: Do not set this parameter to a value higher than 13.
InsUpdAllCols
TRUE or FALSE. Ordinarily when the Siebel application generates INSERT or UPDATE statements to send to the database, the actual statement contains only the columns where data is present or has changed. When there are situations where you generate many statements on a particular table, the differences in the values being updated may prevent you from using an array interface supported by the DBMS. When this feature is set to TRUE, all columns are present in all INSERT and UPDATE statements. This automatically enables two statements issued against the same table in the same business component as part of a batch operation to use any existing array feature of the DBMS. |
IntegratedSecurity
TRUE or FALSE. When TRUE, the Siebel client is prevented from prompting the user for a username and password when the user logs in. Facilities provided in your existing data server infrastructure determine if the user should be allowed to log into the database. This parameter is set for your server data source. However, it is supported for Oracle and Microsoft SQL Server databases only. The default value is FALSE. For additional information, refer to your third-party documentation. For Oracle, refer to the OPS$ and REMOTE_OS_AUTHENT features. For Microsoft SQL Server, refer to Integrated Security. |
MaxCachedCursors
Specifies the maximum number of SQL cursors that can be cached in memory for a database connection. The default is 16. Caching SQL cursors can improve response time and CPU usage because an SQL cursor does not have to be prepared each time it is executed. If memory usage is not a concern, you may consider increasing the value of this parameter. |
MaxCachedDataSets
Specifies the maximum number of data sets that can be cached in memory for a database connection. The default is 16. A data set is the set of records that has been retrieved by the execution of a business component. Data-set caching applies only to those business components for which the Cache Data property has been set in Siebel Tools. Caching data sets for frequently visited business components can improve response time and CPU usage. If memory usage is not a concern, you may consider increasing the value of this parameter. |
MaxConnections
Number of connections that can be made to the data source database server. |
MaxCursorSize
Sets the total number of rows that can be returned in a result set. MaxCursorSize is intended for use only with IBM DB2 UDB for OS/390 and z/OS, and must be set as described in Implementing Siebel Business Applications on DB2 UDB for z/OS. If you are using another database, do not set this parameter to anything other than the default value (-1), or database behavior is adversely affected. MaxCursorSize and PrefetchSize are used together, and must be set to the same value. See also the description for the PrefetchSize parameter. |
NonSQL
TRUE or FALSE. Setting that indicates that the data source does not use an SQL DBMS to retrieve its data. This would be used only in conjunction with a specialized business component that would build internally. It would never be arbitrarily set by a Siebel customer. |
PrefetchSize
Sets the number of rows that the Siebel application reads initially as part of a query execution. PrefetchSize is intended for use only with IBM DB2 UDB for OS/390 and z/OS, and must be set as described in Implementing Siebel Business Applications on DB2 UDB for z/OS. If you are using another database, do not set this parameter to anything other than the default value (-1), or database behavior is adversely affected. MaxCursorSize and PrefetchSize are used together, and must be set to the same value. See also the description for the MaxCursorSize parameter. |
PrimaryEnterprise
The name of the Enterprise Server you want to administer from the client machine. Set this parameter to view or change information in the Server Administration screens. |
ReverseFillThreshold
When the current query contains many rows, it may be very inefficient to read sequentially through all of them if the user hits the End button. For this reason, the customer may configure a threshold value to invert the current sort, re-execute the query, and fill the data buffers from the end. This is hidden from the user. |
SortCollation
Allows the user to specify sorting order on the local database or Sample Database. The SortCollation parameter is not a default part of the configuration file, so it must be added manually in order to take effect. If this parameter is not present, sorting in Siebel applications when using SQL Anywhere uses the binary sort order as identified here. Customers using languages other than English (particularly those using accented characters) may prefer to use an appropriate setting from the list below. NOTE: Setting this parameter to a value other than binary affects the sort performance.
After this parameter is changed, the Siebel application must be restarted in order for the change to take effect. The valid values of the SortCollation parameter, supported by the SQL Anywhere database, consist of the following values: ISO 14651 Unicode multilingual (Default): default ISO 14651 Unicode multilingual ordering standard: 14651 (produces same results as default sort collation) |
SortCollation
Big5 (Traditional Chinese) binary order: big5bin Binary sort: binary (produces UTF-8 binary order) CP 850 Western European: no accent: altnoacc CP 850 Western European: lower case first: altdict CP 850 Western European: no case, preference: altnocsp CP 850 Scandinavian dictionary: scandict CP 850 Scandinavian: no case, preference: scannocp CP874 (TIS 620) Royal Thai dictionary order: thaidict CP932 (Japanese on Windows) Shift-JIS binary order: sjisbin CP932 (Japanese on Windows) Shift-JIS with Microsoft extensions binary order: cp932bin GB2312 (Simplified Chinese) binary order: gb2312bin GB 2312 (Simplified Chinese) Pinyin phonetic order: gbpinyin EUC JIS (Japanese on UNIX) binary order: eucjisbin EUC KSC (Korean) binary order: euckscbin ISO 8859-1 ('Latin-1') English, French, German dictionary order: dict ISO 8859-1 ('Latin-1') English, French, German no case: nocase ISO 8859-1 ('Latin-1') English, French, German no case, preference: nocasep ISO 8859-1 ('Latin-1') English, French, German no accent: noaccent |
SortCollation
ISO 8859-1 ('Latin-1') Spanish dictionary: espdict ISO 8859-1 ('Latin-1') Spanish no case: espnocs ISO 8859-1 ('Latin-1') Spanish no accent: espnoac ISO 8859-2 Hungarian dictionary: hundict ISO 8859-2 Hungarian no accents: hunnoac ISO 8859-2 Hungarian no case: hunnocs ISO 8859-5 Cyrillic dictionary: cyrdict ISO 8859-5 Cyrillic no case: cyrnocs (Not supported for Sybase) ISO 8859-5 Russian dictionary: rusdict ISO 8859-5 Russian no case: rusnocs (Not supported for Sybase) ISO 8859-7 Greek dictionary: elldict ISO 8859-9 Turkish dictionary: turdict ISO 8859-9 Turkish no accents: turnoac (Not supported for Sybase) ISO 8859-9 Turkish no case: turnocs (Not supported for Sybase) Unicode UTF-8 binary sort: utf8bin (produces same results as binary sort collation) NOTE: In the values above, no accent indicates that the accented and nonaccented characters are treated equivalently by the sort. No case indicates that the sort ignores case. Preference indicates that uppercase records appear before lowercase records where the letter is the same but the case differs.
SqlStyle
Indicates what kind of SQL to send to the database you are using. When generating SQL to send to a DBMS, the application needs to construct the SQL statement to suit the particular DBMS. The value of this parameter is automatically set by the Siebel client or server installer, according to database information you specified. The local database or Sample Database, based on SQL Anywhere, use Watcom. Server databases such as IBM DB2 Universal Database, Microsoft SQL Server, or Oracle use the style applicable to the particular DBMS. |
TableOwner
In a database, tables are identified by both their owner and their name. When queries that reference tables are issued, the tableowner must be included in those references (for example, SIEBEL.S_EVT_ACT, where SIEBEL is the tableowner). |
UpperCaseLogin
The default is FALSE. If set to TRUE, the user ID, when a user logs in, is converted to uppercase before it is sent to the database for authentication. This value is applicable only if the database is used for authentication; the value of the parameter is ignored when SecurityAdapter is set to a non-empty value. Use this parameter if you want to enforce a policy of having all database accounts in uppercase on a case-sensitive database, but you do not want users to worry about case when they type in their user names. NOTE: The value of UpperCaseLogin does not affect the password.
