Testing Siebel Business Applications > Functional Test Object Reference > Common Test Automation Object Methods >
GetClassCount Method
The GetClassCount method searches the repository for objects of the specified type and returns an Integer indicating the number of such objects.
Available from
SiebApplet Object, SiebApplication Object, SiebCurrency Object, SiebScreen Object, SiebView Object
Syntax
GetClassCount (ClassName)
Argument
Description
ClassName
A String that specifies the type of object to be counted
Returns
Integer indicating the number of objects of the specified type.
