Testing Siebel Business Applications > Functional Test Object Reference >
SiebScreen Object
The SiebScreen object provides methods and properties that allow you to manipulate a screen object in a test automation environment.
Parent
The SiebScreen object is a child of the SiebApplication Object.
Type
The SiebScreen object is a container object that is one of the Application Hierarchy Objects.
Events
The SiebScreen object has no events associated with it.
Methods
The following methods are available from the SiebScreen object:
For a description of these methods, see SiebScreen Methods.
Properties
The SiebScreen object has the following properties.
Property Name
Type
Description
ClassName = "SiebScreen"
Const String
See Common Test Automation Object Properties for a description of this property.
RepositoryName
String
UIName
String
