Testing Siebel Business Applications > Functional Test Object Reference > Common Test Automation Object Methods >
IsExists Method
The IsExists method returns a Boolean value indicating whether or not the specified object exists.
Available from
SiebMenu Object, SiebPageTabs Object, SiebPDQ Object, SiebPicklist Object, SiebThreadbar Object, SiebTree Object, SiebViewApplets Object
Syntax A (SiebMenu Object, SiebViewApplets Object)
IsExists (RepName)
Argument
Description
RepName
A String that indicates the RepositoryName of the object
Syntax B (SiebPageTabs Object)
IsExists (RepName, [NavType])
Argument
Description
RepName
A String that indicates the RepositoryName of the PageTab or View object
NavType
A String that indicates the type of navigation object (Screen for a PageTab object, or View for a View object)
Syntax C (SiebPDQ Object, SiebPicklist Object)
IsExists (ItemName)
Argument
Description
ItemName
A String that indicates the visible title of the PDQ or Picklist object
Syntax D (SiebThreadbar Object)
IsExists (LinkName)
Argument
Description
LinkName
A String that indicates the visible title of the threadbar item
Syntax E (SiebTree Object)
IsExists (Position)
Argument
Description
Position
A String that indicates the position of the node in the tree. It is in the format
   first-level-position.second-level-position.third-level-position
where each position is in relation to its current context within the preceding level. For example, 1.3.2 represents the second node within the third node of the first root node.
Returns
A Boolean value indicating whether the specified object exists (TRUE) or does not exist (FALSE).
