Testing Siebel Business Applications > Functional Test Object Reference >
SiebTextArea Object
The SiebTextArea object provides events and properties that allow you to manipulate a text area in a test automation environment.
Parent
The SiebTextArea object is a child of the SiebApplet Object and the SiebList Object.
Type
The SiebTextArea object is one of the Core Control Objects.
Events
The SiebTextArea object has the following event.
Event Name
Description
SetText (TextValue)
Enters text into the text area. TextValue is a String that specifies the text to enter.
Methods
There are no methods available from the SiebTextArea object.
Properties
The SiebTextArea object has the following properties.
Property Name
Type
Description
ClassName = "SiebTextArea"
Const String
See Common Test Automation Object Properties for a description of this property.
IsEnabled
Boolean
IsRequired
Boolean
RepositoryName
String
Text
String
UIName
String
