Upgrade Guide > How to Perform a Siebel Database Upgrade > Road Map for Performing a Siebel Database UpgradeUpgrades: All Siebel upgrades. Environments: Development, production test, production. Use one of the road maps listed below to guide you through the steps for upgrading your Siebel Database. Each road map consists of a group of processes. Each process consists of a numbered list of tasks. After you complete the tasks in a process, go on to the next process in the road map. When you have completed all the processes in the road map, the upgrade is complete. Depending on your database and installed release, you may not need to complete all the tasks in a process. Before starting a task, check the applicability information at the beginning of the task and verify the task applies to your upgrade. Choose the most applicable road map to perform the upgrade:
Road Map for Upgrading from Siebel 6.xIf you are upgrading from Siebel 6.x, you must first upgrade to Siebel 7.7. Then, you upgrade from Siebel 7.7 to the current release. To upgrade from Siebel 6.x to Siebel 7.7, see the latest Siebel 7.7 version of the Upgrade Guide on Oracle's Siebel SupportWeb. Direct upgrades from Siebel 6.2.1 of Siebel Financial Services to the current release of Siebel Industry Applications on IBM z/OS platforms are supported. To perform this upgrade, see Upgrade Guide for DB2 UDB for z/OS. Road Map for Upgrading from Siebel 7.8.1 to Siebel 7.8.2If you are running Siebel 7.8.1 in your production environment, contact Oracle's Siebel Expert Services for help in upgrading to Siebel 7.8.2. If you are running Siebel 7.8.1 only in your development or production test environment, choose one of the following strategies to upgrade from Siebel 7.8.1 to 7.8.2. Upgrade from Siebel 7.8.1 to 7.8.2.Perform a full upgrade, including repository merge.
Return to Siebel 7.x, then upgrade to 7.8.2.In this strategy, you return your development and production test environment installations to your previously-installed 7.x release. You then perform a standard upgrade to Siebel 7.8.2.
Uninstall Siebel 7.81 then install 7.8.2.In this strategy you do not perform an upgrade in the development and production test environments. Instead, you uninstall Siebel 7.8.1 and the Siebel Databases in these environments. Then you install a full Siebel 7.8.2 distribution and new Siebel Database.
Road Map for Upgrading from Siebel 7.x or Siebel 7.8.1 on IBM DB2 UDB for z/OSUpgrading from Siebel 7.x or Siebel 7.8.1 on IBM DB2 UDB for z/OS is described in Upgrade Guide for DB2 UDB for z/OS. Road Map for Upgrading From Siebel 7.x if You Have a Development EnvironmentIf you are upgrading and have a development environment, complete the processes in this road map in the order shown:
Road Map for Upgrading From Siebel 7.x Without a Development EnvironmentIf you are upgrading and do not have a development environment, complete the processes in this road map in the order shown. Upgrading without a development environment means the following are true:
If your upgrade meets these criteria, complete the following processes in the order shown:
Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
