Table 6. View Menu Options
Windows |
Properties Window |
Shows or hides the Properties window. |
Applets Window |
Shows or hides the Applets window. |
Controls Window |
Shows or hides the Controls window. |
Bookmarks Window |
Shows or hides the Bookmarks window. |
Web Templates Window |
Shows or hides the Web Templates Explorer window. |
Refresh Windows |
Requeries and updates the state of dockable windows. |
Editors |
Applet Editor |
Opens the selected applet in Applet Layout Editor, including the Controls/Columns window. |
Server Script Editor |
Opens the Siebel Script Editor. Editor may be specifically defined or be set to a default. |
Browser Script Editor |
Opens the Siebel Web Script Editor, which is used to access scripts that control the presentation and behavior of applet controls and list columns in a Web applet template. |
Visualize |
View Details |
For more information, see Viewing Object Relationships. |
View Relationships |
View Descendents |
View Web Hierarchy |
Debug Windows |
Calls (CTRL+L) |
Opens the Calls window for display of the call stack of the Siebel VB or Siebel eScript script currently being debugged. |
Watch (SHIFT+F9) |
Opens the Watch window for display of the values of local variables in the Siebel VB or Siebel eScript script currently being debugged. |
Errors |
Opens the Errors window for display of the run-time errors in the Siebel VB or Siebel eScript script currently being debugged. |
Preview |
The preview of a Web view layout depicts the container page, screen bar, and view bar. |
ActiveX Methods |
Allows you to view the methods for the current ActiveX control in the Applet Designer. |
Toolbars |
Displays or hides the various toolbars: Edit, History, List, Debug, Web Controls, and Configuration Context. |
Status Bar |
Displays or hides the Status bar at the bottom of the Siebel Tools window. |
Object Explorer (CTRL+E) |
Displays or hides the Object Explorer. |
Options |
Opens the Development Tools Options dialog box, in which you can set general preferences and settings for language, check-in and check-out, list views, scripting, Web template editor, debugging, visualization, Object Explorer, and database. Siebel Tools options are stored in a user preference file, which is located in SIEBEL_TOOLS_ROOT\BIN. The user preference filename is loginID&SiebelTools.spf. |
