Using Siebel Tools > About the Siebel Tools User Interface > About Siebel Tools Toolbars >
List Toolbar
The List toolbar contains buttons that apply to objects in the Object List Editor. The buttons let you insert new records, move forward and backward, work with queries, and sort objects. Table 16 describes the List toolbar buttons.
Table 16. List Toolbar Buttons
Add New Record |
Creates a new object in the Object List Editor, with the cursor positioned in the first required property. |
First Record |
Goes to the first object in the list. |
Previous Record |
Goes to the object above the current selection. |
Next Record |
Goes to the object below the current selection. |
Last Record |
Goes to the last object in the list. |
New Query |
Allows you to specify one or more restrictions on the set of objects to be displayed in the current Object List Editor. |
Execute Query |
Executes the query you have just specified, causing the restrictions to take effect. This has the same effect as pressing ENTER. |
Sort Ascending |
Changes the order in which objects appear by sorting them in ascending order on the currently selected property column. |
Sort Descending |
Changes the order in which objects appear by sorting them in descending order on the currently selected property column. |
