Table 17. Debug Toolbar Buttons
Check Syntax |
Compiles the current script and verifies syntax. |
Start |
Starts the application. A dialog box with startup parameters also appears. |
Break |
Stops the execution of the currently running script. If Siebel VB or Siebel eScript is not executing, no operation is performed. |
End |
Stops the execution of the application and returns to the Siebel Script Editor window. |
Toggle Breakpoint |
Sets or removes a breakpoint on a specific line of code. |
Watch |
The Tools menu establishes variable watches, so you can monitor the contents of program variables in the Variable window during execution of Siebel VB and Siebel eScript routines. |
Calls |
Displays the list of Siebel VB or Siebel eScript routine calls executed up to the point where the application was stopped. |
Step Into |
Executes the next line of script code. If this is a subroutine or procedure call, then execution continues within that procedure. |
Step Over |
Advances the application to the script code line just after the current subroutine or procedure. Execution remains at the level of the current procedure. |
