Table 18. Web Controls Toolbar Buttons
Change Template. Displays the Choose Template dialog box that lets you select a different Web template. |
Edit Template. Opens the template editor you defined as your external Web template editor in your options. |
Select. Lets you select an object in the layout. |
CheckBox. Creates a check box. |
ComboBox. Creates a combo box. |
Text. Creates a text box. |
TextArea. Creates a text area. |
Hidden. Creates hidden HTML. |
Password. Creates a text box where the user enters a password during logon. |
Link. Creates an HTML link control. |
MailTo. Creates a mail-to link. |
Button. Creates a button. |
Label. Creates a label on templates. |
URL. Creates a link to an external URL on templates. |
ActiveX. Creates an ActiveX control on templates. |
Text List Column. Creates a list column that contains HTML text. Available for list applets only. |
Checkbox List Column. Creates a list column that contains HTML check boxes. Available for list applets only. |
Custom Control. Creates a custom control on a template. You can select a custom control from the Control Type drop-down list, and then drag the Custom Control button to the designer to create the custom control. |
Shift to previous placeholder in applets based on nongrid Web templates. Moves the selected control to the previous placeholder. |
Shift to next placeholder in applets based on nongrid Web templates. Moves the selected control to the next placeholder. |
