Using Siebel Tools > Working with Objects >
Generating Reports About Object Relationships
You can generate reports about the relationships between certain object types in the repository. This section provides an introduction to using the reports facility; for more information, see Siebel Reports Administration Guide.
The list of records included in a repository report is not dependent on the currently selected object in the Object List Editor—for example, if you select the Contact business component in the Object List Editor and generate the business components and fields report, the report shows all business components, not just the Contact business component.
Generating Reports for a Single Object Type
To restrict a report to a single object type (that is, one business component, business object, dock object, table, or workflow object) run a query in the Object List Editor (for the parent object type) that restricts the list to the one object.
The following example shows how to get the Tables report for S_ORG_EXT.
To get a Tables report for the S_ORG_EXT table (an example)
  1. In the Object Explorer, select the Table object type.
  2. In the Object List Editor, click anywhere to make it the active window.
  3. Choose Query > New Query.
  4. In the Name field, type S_ORG_EXT and press ENTER.
  5. Choose Reports > Tables.
    The generated report provides information only for the S_ORG_EXT table.
Generating Reports for Ranges of Objects
You can use a similar approach to restrict a report to a range of objects that have a property value in common. The report includes only those objects that match the current query criteria. For example, you can generate a Tables report of all extension tables, a business components report of all business components of a specific class, or any of the reports restricted to a single field.
Available Reports
The current object type in the Object Explorer determines the list of reports in the Reports menu. Repository reports are listed by current object type in Table 35.
Table 35. Reports Available for Each Object Type
Object Selected in Object Explorer
Report Menu Option
Applets by BusComp
Lists the applets assigned to each business component.
Business Component
Business Component and Fields
Lists the fields in each business component alphabetically. For each field, the base column and join table, if any, are identified.
Business Object
Business Object and Components
Lists the business object components in each business object. For each business object component, the business component and link are identified.
Business Service
Business Service Summary
Lists a summary of all business services.
Business Service Detail
Lists all business services with details.
Dock Objects
Repository Dock Objects
For each dock object, displays selected properties, and lists the member tables, visibility rules, and related dock objects.
Project List
Lists all projects, and identifies the locking status, person locked by, and locked date for each.
For each table, displays selected properties, and lists the columns. The name, physical type, length, scale, comments, and various other properties are identified for each column.
Workflow Policy Object
Workflow Policy Objects
Lists the workflow components in each workflow object, and within each workflow component lists the columns.
Using Siebel Tools
