Using Siebel Tools > Working with Strings and Other Locale-Specific Data > Using Batch Files to Convert and Consolidate Strings > Conversion Batch FileThe parameters for running the conversion batch file, strconv.bat, are listed in Table 48. Example: CAUTION: If your Siebel Tools install path contains spaces, the strconv.bat file will return errors. To ensure the batch file functions properly your Siebel Tools install path must not contain spaces, or, if your install path does contain spaces, you must enclose the path with quotes. |
Using Siebel Tools |
