Using Siebel Tools > Working with Strings and Other Locale-Specific Data > Using Batch Files to Convert and Consolidate Strings >
Consolidation Batch File
The parameters for running the consolidation batch file, strcons.bat, are listed in Table 49. Example: strcons Action User_ID Password
Table 49. Batch File Parameters for Running Consolidation
strcons.bat |
Consolidation export, file split, and import batch file. |
Action |
The options are export or import. When set to export, the consolidation process exports all convertible locale records. When set to import, the consolidation process imports the files in the working directory designated by the TEST_LOCATION parameter set in the batch file. |
User_ID |
The user name used to login to the Siebel application. |
Password |
The user's password. |
