Using Siebel Tools > Working with Strings and Other Locale-Specific Data > Locating Orphaned String References After UpgradeUpgrades from one release of Oracle's Siebel Business Applications to another release may result in the "disappearance" of certain string references. The Fix Strings Utility allows you to locate these orphaned strings, and update them with new references. This process is run as a business service through the Consoleapp.exe utility, located in the SIEBEL_TOOLS_ROOT\BIN directory of your Siebel Tools installation directory. You find and report orphaned string references in the Siebel repository using the following procedure. To locate orphaned string references
ExamplesThis command example shows how you run the utility for the object type Business Service, and write information to the fixstrings.log directory, and progress to the command window: consoleapp This command example shows how you run the utility on all object types, write the results to temporary fixstrings.log file: consoleapp |
Using Siebel Tools |
