Siebel Business Process Framework: Workflow Guide > Reference Materials for Siebel Workflow > Manipulating and Processing Data >
Accessing Run-Time Event Data
This topic explains how to access run-time event data from a workflow process. To access run-time event data from a workflow process
- Expose the WF Step Branch object type in the Object Explorer.
- In the WF Step Branch OBLE, define the properties for a WF Step Branch object definition. Use the sample data described in the following table:
Name |
Enter a name for the branch. |
Type |
Condition |
Event Object Type |
Applet |
Event |
InvokeMethod |
Event Object |
Choose the name of the event object that triggers the workflow. |
Sub Event |
NewRecord |
Comments |
Optional |
Event Cancel Flag |
The default is blank. |
- Set up process properties in the Process Designer.
For information, see About Process Properties.
- Click the first step in your workflow process, then add a new output argument for each process property you need to populate that references a run-time event.
To add a new output argument, enter values into the argument fields displayed under the Output Arguments tab in the MVPW. Use the sample values described in the following table:
Property Name |
Enter a name for the property. |
Type |
Expression |
Value |
GetProfileAttr("RestrucOut") Note: As you are filling in the Profile Attribute field, note the name you give to each of the Profile Attributes property values. These are used in Step 9. |
Output Argument |
Leave default value. |
Business Component Name |
Business Component Field |
Comments |
Optional |
- Activate the workflow process.
For more information, see Process of Deploying a Workflow Process.
- Since the workflow process references run-time events, you must load the run-time events:
- Navigate to Administration-Runtime Events > Events.
- Click the Menu button on the Events list applet, then choose Reload Runtime Events.
- Query the Event field for the run-time event you defined in Step 4.
- Drill down on the Action Set Name field.
- , Add a new Action for each process property that is populated by using a run-time event.
For example, you can create a new action to set the ACU Transaction ID and call it Set ACU Trans ID. Tasks you should perform for each new action include:
- From the applet menu, choose Reload Runtime Events.
